Our heating system has a number of little problems, including:
- some rads get a bit warm when hot water (only) is selected on the controls
- a couple of rads do not get as warm as the others when CH is on
- air can be heard in the system (bubbling noise if you listen to flow/return pipes near boiler)
- lots of sludge in the system
- one rad that is on a separate loop of its own never comes on
- when we have CH on and HW off, we get pumping over (i.e. very hot water going into F&E tank
- there is a lot of pipework near the boiler which has obviously leaked a bit in the past (no current leaks though) as the joints are all covered in limescale.
I have had two plumbers quote to deal with all this.
Both said that the vent pipe and feed pipe are connected in the wrong place (they tee off in the airing cupboard rather than next to the boiler).
One plumber said that all my problems will be solved by replacing the motorised valves and converting to a sealed system for about £700.
The other plumber said that whatever I do I need a powerflush first of all. And that then I should stick with an open vented system and simply have some new pipework run from the boiler to the airing cupbaord so as the vent is coming off the system in the correct place (next to boiler).
He also said the pump needs upgrading as it is not big enough for our system. Current pump is a Grundfos UPS 15-50.
His price for all that is £1500.
So my question is: what are the drawbacks of the sealed system?
The £1500 guy said he wouldn't recommend a sealed system due to the potential for it showing up any defects in the existing pipework.
Is that the only drawback?
Is the powerflush worth having?
Would my best bet be to have a powerflush and then a sealed system - which would presumably cost somewhere between the £700 I've been quoted for the sealed system and the £1500 I have been quoted by the other guy?
If it makes any difference the system dates from the early 60s. However, some of the pipework will be newer than that because the boiler was moved from the kitchen to the garage at some point (I'd guess about 15-20 years ago).
The system has 10 double panel rads, one single panel, and three towel rail rads.
Thanks in advance.
Dave
Thanks in advance.
Dave
