I have an ongoing problem with my 10 year old Megaflow tank. After approx 6 weeks the air-gap gets reduced to the point where water comes out of the T&P valve when the system heats up. The air-gap has been re-set several times and the result is the same. The T&P valve was replaced on the advice of Heatrae but water now comes out of the “expansion” valve instead. I suspect a very slow leak in the tank but it’s very difficult to be sure as it’s encased in foam. I live in a close of 9 houses all with the same system and I’m the only one with this problem which should rule out environmental factors.
Does anyone have any ideas before I fork out for a new cylinder?
JimG
JimG
