Hi, my heating system does not work, the boiler fires up and heats the water only. If the room stat is turned up to induce the heating to come on nothing happens, the stat is functioning. If the Honeywell Sundial Y valve is manually moved to the other position the heating comes on. Am I right in saying then it is the motorised Y valve and therefore needs replacing?
Tim.
Tim.
