Vailllant ECOmax 618 E, cuts off
25 Nov 2005
Dear All
I have a problem with my Boiler which is Vailllant ECOmax 618 E. When extrenal conrols calling for heat the following takes place:
1-The boiler fire up and you hear the pump running.
2- it runs for 20 seconds then you hear the flame stops.
3- after 5 seconds the boiler fire up again and you hear the pump running.
The above keep repeating as long as external controls calling for heat.
many thnaks
Any 'F' codes present in the digital display?
Press the 'i' button whilst it is doing this and see what 'S' code it is showing.
Hi Dave,
thnaks for thr reply
No 'F' code present. I do not have an 'i' button. The only buttons are RESET, Spanner Picture, +, - and Rediator picture.
Hi Dave,
Strange, my relative got a Vaillant ecoMAX boiler from the 600 series which was released in 2005 I think. It has got an "i" button and all buttons present on the ecoTEC range. Are you talking about the boiler control panel?
Just double checked.
Ecomax has the same 'i' button. Top right above the ladder in the middle.
