Hello all, a plea for help. Before I hand over my wallet to an engineer as he sucks the air in through his teeth shaking his head. Can I ask you some of you wise and skilled men and women to impart your sacred knowledge upon me? Or even tell me the fault if you’re particularly up for a challenge.
Q. Sime Super Plus, combi boiler. Works fine most of the time but on odd occasions and its getting more frequent especially on timer, it will make awful... I can’t quite describe: Buzzing/humming, ‘BVVVVVVVV’ sound which comes from the boiler it’s self and vibrates through the pipes and flooring. At 3 in the morning it sounds just like someone’s got a masonry drill and is boring through the wall. I am not sure if the water is still pumping hot as the sounds is so bad I turn it off, for mine as well as the neighbours sake. I guess you might even say it sounds as if water pump is pumping dry. But it does it randomly, even when no taps or washing machine is on.
Any advice or help would be truly appreciated, more so I can get an idea when Dick Terpin gives me his invoiced ultimatum. Thanks all for your time and understanding. John.
