Hi
I'm just in the process of having double glazing fitted. Some windows are done today and probably another day or two to go.
The glazing before was single glazing with wooden frames (prob as original) and had later had internal glazing added about 2-3 inches inside.
It all looks immaculate from the outside, well sealed, very pleased with the quality of the units etc.
However, on the inside there are gaps (varying approx 2-5mm) between the frame and the original plaster. The frames seem sized correctly width and height to adequately fill the brickwork.
The added problem is the plaster in the reveals is not the best and taking off the internal glazing has broken/weakened it. In fact round the frame in a couple of places large bits have broken off leaving 1-2 inch gaps of reveal plaster and some brick.
The original plaster also seems to slope up at the edge slightly. I guess where it was plastered up to the original wood frames. This I would imagine needs chipping off to lower to get a flat finish to the reveal.
I think the original plan for the fitters was to fit plastic strips around the inside, but given the state of the plaster, they requested clarification this morning on what I wanted.
The first question is - do double glazing fitters normally make good inside and fill large gaps so that only a plaster skim is needed? Or is this open to debate/prior agreement what they do?
I have a 'willing volunteer' house sitting during the day with them and when the fitters asked them for clarification, I was phoned to double check. They asked if I was going to get it plastered, if so, they recommended they leave on the protective tape on the frames. Is this a cop out?
The second question is if I am expected to fill all gaps and plaster myself, do you plaster directly up to the frame or should there some internal bead fitted to keep it back from the frame?
I can imagine getting the protective tape out after you've plastered up to the edge is a bit difficult. I wouldn't want to slice the UPVC using a stanley knife and cause damage later!
Any prompt advice appreciated, as they will be due to finish in 1-2 days and I'd like to ask some questions.
