could anyone tell me what would be the result of scaled plate exchanger? poor dhw flow, poor h/w temp as there would be karge temp differntial on flow and return? anything else? wouldnt the boiler overheat if the plate was scaled up?thank you
Poor DHW flow if scaled badly on the domestic side. Most plate HE's tend to block on the system side and cause hot/cold hot/cold cycling as the boiler overheats/cools/overheats.
