Unvented water off a combi boiler?
In that case,,,,,, your inherently wrong.
No matter where you put the feed,,,,,, your inherently wrong.
Think path of least restriction :idea:
He's right clf.
Re do the drawing.
Though I think you might get it wrong (again) :wink:
Lets say just for figures 120litre cylinder used, thats 120kilo of water,
boiler and pipework holds 30litres,again just for figures thats 30kilo.
Hot tap is opened, where will the incoming mains want to go.
Oh and by the way, produce stratification in a barrel with water pumped through it.
ChrisR said:
Not too dissimilar to the Glow Worm Ultrapower stored water combi
Different enough though
You clearly should not be in this business.....not unless you are carefully supervised.
I do supervising, and rejection where necessary, as in your case. You'd be packed off to NVQ Level 1, but you'd fail the aptitude test.
He's right clf.
Re do the drawing.
When you understand the arrangement then I might answer your question. :wink:
Also I think you should look up the meaning of stratification. :roll:
You have already made yourself look foolish on this thread along with a few other of the "so called" professionals.
Why continue?.
OK I understand the arrangement, enlighten me.
I know what it is, but how will it happen if hot water is pumped in the top of cylinder and circulated.
By asking a foolish question to a foolish person and getting an answer from another fool :lol:
Why continue?.
ENLIGHTENMENT
Looking to have an unvented connected to a worcester Bosch 30cdi Combi.
The unvented is in situ as is the combi both sited in E16. Can anyone carry this out for me ?[/i][/b]
