Hi all
Just had old heating system (indirect tank for hot water) replaced with closed combi.
I general i'm pretty happy with the results but was surprised to discover that the flow of hot water is not restricted. As a result if hot taps are turned on too far the water is cooler than required. On reading the boiler manual (Biasi Garda he 28kw) it seems restrictors are only fitted to the less powerful boilers in the range. it seems that for our boiler a restrictor is not included as standard but can be added if required.
Now i'm wondering about getting the plumber back to do this (assuming it's not a diy job?) but not sure if it's worth bothering because:
a) maybe there are some cons against getting the flow restricted ?presumably if flow is restricted to produce hot enough water in winter then, in summer, when mains water is warmer the boiler could potentially achieve a greater flow at the required temp (but we will not be able to use this potential if restrictor fitted - if i've understood how they work correctly?)
b) we intend to change all our taps within the next year, so maybe it would be possible / easier to limit the flow at the tap some how?
As always any advice will be much appreciated
