The hot water at the taps from the indirect hot water tank is significantly cooler recently and although the hwt supply pipe at the flow side at the boiler is hot the return seems to me to lower than it should be. I am wondering if the coil in the tank is blocked/restricted with sludge. How likely is this as a possible explanation?
