I am about to start first fit on my conversion. I just putting in the ring mains. downstairs, I would like to put in two rings.
1) Normal ring
2) Switched ring.
The idea is that, stuff thats needs to stay on all the time (i.e. the fridge etc) would be on the normal ring as per normal.
BUT, I would like to have a separate ring that I can completely switch off at night - (like the TV on stand by, the microwave etc) The idea is, that on my way to bed, I flick a switch and the switch ring goes off, hence turning off all of those things that would normally have been sat there on standby all night off. Then first one up, puts them all back on... hence we save the money overnight when all are in bed.
So my questions are,
1) what does building regs make of this?
2) Do I wire this say with 6mm coming out of the 32A RCB from the main DIST box, going to say a cooker switch, and then from the cooker switch start the ring as normal? Or any other suggestions??
Any thoughts or suggestions from you guys would be much appreciated.
thanks
Dave
1) Normal ring
2) Switched ring.
thanks
Dave
