Howdo all.
Can someone give me an insight into wiring up underfloor heating. Tried
the quick search but it aint working ???
I have installed the warmup wire system which is all in place and taped
to the floor as tiler is coming tommorow morning to lay Travertine
tiles. I then ran the 2 cold cables including sensor cable up inside stud
walling and into loft then back down to thermostat which is situated outside
the bathroom. Tested system through whole process and everything is
fine which came out at 217.3 ohms.
Now im a bit stumped as to how i can get mains power the the thermostat
which will have to be via the loft.
Thing is all mains power to sockets etc come up from under the floor so
i only have the lighting circuit in the loft which i cant use. Shame
really as it would be easy to do then but noting is ever simple eh.
Only solution i can come up with, is that directly under the bathroom i had
to remove a 4 foot square piece of ceiling due to a leaking pushfit and
that has exposed all the mains 2.5mm cabling. Can i split into one of
those mains cables using a heavy duty 30amp junction box ????
This will enable me to run a 2.5mm t&e from JB, up bathroom stud wall,
into loft and down to thermostat.
Only thing is that the junction box wont be accessable and it will be
covered up by new ceiling.
Please can someone give me some advice on the best solution.
Also i know all this comes under part P but all work will be checked out
by qualified sparky when work is complete.
Kris
Kris
