We have been having a problem with the central heating system recently and it's getting worse, so I decided to ask for help.
To summarise the issue:
Boiler Vokera Compact SE 28
Closed circuit.
Losing pressure to the point the boiler is not starting until the circuit is topped up. This is now an operation that needs to be done daily. The pressure is lost whether the heating is on or off.
We have checked every radiator in the house, and every valve. We have replaced any radiator that seemed too old, and all the valves in the house.
We have brought in a specialist to check the boiler and this has passed fine.
So the only obvious cause is : there is a leak somewhere.
We can't see any water on the ceiling. So we assume the problem is not at the first floor, or we would see a wet patch somewhere after so many days. We looked under the floorboards near each radiator at groundfloor level, and it's all dry.
Could you please advise on any method that we could use to find this leak. Ideally something a little bit less destructive than tracing every pipe in the house through floors and walls. Any specialist services we can engage to help us find it. Any advice much appreciated.
Closed circuit.
