Hi I have a Glowworm 30HXI Gas Boiler
Recently it developed a problem, I called our cover provider Homeserve and they sent out a repairman. It required the Burner Door Seal (801635) to be replaced.
No problem, however the repairman was unable to get the part and after 10 days our home is freezing. I obtained the part myself and asked them to fit the part.
In doing so he damaged another seal/gasket.
Looked at the manual and he should removed the burner and fan as one unit to replace the burner door seal. However he removed the ducting from the fan to burner to remove the burner unit. Must have been quicker he thought. However in doing so he damaged another seal/gasket, which is required. However since he never got the original part it will be quicker if I source the new part which is now needed.
In the diagram below we need the gasket/seal between ducting (coloured red) and the burner plate. Can anyone identify the part and glowworm part number. So I can order it and get them back to fit.
