Protherm E80 F1 fault
13 Jan 2009
Staffordshire
My boiler keeps giving me a F1 code. We have replaced the overheat stat and the thermister this worked for a while. However, the problem is happening again. when we change the temperature on the boiler ie from 45 degrees F to 55F or 55 to 65, works for a while without us having to reset it and then after a few days the same problem occurs. Could it be the memory board as suggested by the engineer that was called out.
If F1 is only an overheat code then one would expect that its overheating.
That would need a CORGI to check all the gas parameters.
A thermal survey will identify any blockages or lack of flow.
If the F1 also includes burner lockout then again you need a CORGI to determine the cause.
I suppose the boiler has never been serviced since it was installed?
Tony
Thanks Tony, we've done all that, still having problem.
Tony
If you had really done all that then you would have identified the fault!
You would also be CORGI registered !
Tony
Tony
We had an engineer in to look at it he suggested that it could be the electronic board as he was unsure and all thermal parts had already been replaced previously.
Why do you keep saying the same reply. I am not stupid and cause we had a registered engineer. We are concerned about replacing the boiler when it might not be necessary. The engineer advised us not to spend any money repairing the boiler,but as the boiler is only 6 years old we thouight it might be worth spending our money reparing it rather than replacing it. I was seeking advice not a lecture.
Tony
Well that says it all.
He is unsure of what the problem actually is!
I would suggest that you get a proper boiler engineer who has some diagnostic skills!
As you clearly dont want my advice, I will leave you at the mercy of your nupty engineer who wants to fit an expensive new boiler because he cannot diagnose the simple fault on yours!
Any competent engineer is able to diagnose faults and repair boilers. Thats what we do! Yours clearly cannot!
Tony
