I have a 100 litre hot water cylinder and a 25 gallon cold tank and have bought 2 mixer showers to install in seperate bathrooms, they will not be used at the same time. I was planning on fitting a single impeller pump and an equalising valve so i could use the hot cylinder off a surrey flange and cold from mains rather than the cold tank. Would that work and if i purchased a low powered pump, any ideas of possible showering time? Worried the cylinder isn't big enough..
It's heated from a heat only boiler.
