- Joined
- 29 Mar 2005
- Messages
- 178
- Reaction score
- 0
- Country
Firstly, apologies if this has been covered before - I've tried searching the forum but haven't found an answer.
Our shower trap has started to leak at the top under the shower tray. After examining it, I can see that this is because the person who installed it had positioned the shower tray so that the edge of the floor board was pushing against the nut that tightens the waste pipe onto it, thus forcing the trap to tilt slightly and strain its mounting. You can see in the pictures where this was because I used a small drill to remove the offending bit of floor board and now it looks a bit ragged there.
I figure the only way to fix this properly is to remove the trap (and possibly replace it). However, I'm not sure how it comes off.
What doesn't help is that the trap just happens to line up with a floor joist. There is only literally about 2mm clearance between the bottom of the trap and the joist. As you can see in the pictures, the bloke who fitted it cut an uncomfortably large notch out of the joist so that the trap could fit. I've only just noticed this today when I removed a section of living room ceiling to gain access. Fortunately this is fairly close to the end of the joist!
View from the top:
Underneath. You can see where I had to hack a bit of floor boarding away at the top of the picture:
Here you can clearly see where it's leaking and how this corresponds to where the bit of flooring would have been pushing the trap across:
While this is a complete pain, fortunately the living room, whose ceiling I had to hack into, is currently being prepared for plastering. Glad this didn't happen just AFTER the plastering!
View from the top:
