Hi all,
I have today had a new Baxi Solo HE 15 installed.
I have a fully pumped system. New Diverter valve, Grundfoss pump 2 years old ish, so quite new & working fine (currently on lowest of 3 speeds). Potterton programmer EP2000/2 (16 programme). Recently installed.
Old boiler worked fine in terms of switching HW/CH and staying off if both CH & HW set to OFF - only replaced due to badly corroded heat exchanger (on advice of plumber who serviced boiler).
Anyway, it seems that even if the controller has both CH & HW OFF, boiler kicks in for a few seconds every couple of minutes and heats the water - HW is very hot! I practically emptied the tank of hot water (just by turning hot water taps on and replacing with cold in the tank) but the boiler kicked in and continued to heat the hot water.
I don't understand! I will be calling engineer back - but any heads up in advance would help me to getting the right fix. Any suggestions?
Thanks all!
Thanks all!
