- Joined
- 1 Mar 2009
- Messages
- 110
- Reaction score
- 1
- Country
I am going to tackle this job tomorrow. Have read many posts here for replacing the element, and am reasonably confident of successfully removing the element and installing new one. Only want to be certain that there are no untoward issues with draining of the system and refilling, because of it being an unveted system with pressurized expansion tank, which has a car tyre type schrader valve filler.
As far as I can see, all I need to do is to turn off the cold water inlet, open all hot taps, open the drain valve at the bottom and let it run out.
Questions are:
1. Will the pressure vessel lose the pressure when water is drained?
2.If so, I will need to repressurise the expansion tank when filling up the cylinder, otherwise the expansion vessel will get filled with water!
The system is the unvented Range Tribune HE, and is installed with all the safety features, none of which will be altered in any way. I see it as a straightforward job, but may need careful repressurising to avoid the expansion tank filling up with water!
Any advice will be highly appreciated.
Questions are:
