Hello all, our boiler has decided not to work.
It is an Ideal Classic and it was installed in 1992/93.
When you switch on the heating or hot water the boiler clicks but dosn't fire up and the pump starts running
I have been up in our airing cupboard and i don't know if the problem might be with my mid position valve/actuator.
It is an ACL Drayton (Invensys) MA1/679-3 Mid-Position Motorised Valve. I put it in in october last year as the old valve had sized solid.
The reason i wonder if it is the actuator is that it is warm to the touch. The valve itself is cold, it is just the actuator that is warm. Is this normal?
When selecting hot water/heat the valve moves freely so it isn't jammed again. I am just concerned as to why it is warm. I am assuming that there are microswitches or something in there as i can also hear a click when selecting water/ heat etc..
To get a replacemnt actuator is going to cost about £30 but before i go and order one i would value someones opinion.
Regards
Regards
