I am having a window fitted in a new build extension. Originally I ordered a supply and fit through a double glazing company (quoted £430). They told me the window would be installed in 3 weeks but a week and half later I hadn't even had the survey. I contacted them for s supply only quote and that came in at £259. I've informed them that I was cancelling my original order and was going to order through supply only.
A couple of questions to clarify: Is it OK if I fit the window myself ( or my builder) rather than a Fensa installer. Its a new extension so I presume all the works will be covered by the BCO certificate.
Secondly the size of the opening is 1060mm by 2112mm, would it be OK to order windows of 1050mm by 2100mm or should I allow a greater tolerance.
Thanks for any advice
