BG WILL FIX IT FOR just under 200 quid so cheaper than baxi
Do they give a full 12months warranty on the entire boiler after the repair as Heateam do?
i thought the heating was working fine which would rule out venturi/aps etc
B.G Suck they drive little vans full of paper and stuff.
HEATEAM vans are big and full of boiler spares......perfect for repairing your boiler.![]()
Right I have an update on this situation.
Baxi Heat Team came out checked it over changed venturis and said it needed a new fan but he did not have one. He came back 3 days later and replaced the fan still said fault on fan or flue and it still did not work. I recommended to him to change the PCB and it solved the fault on flue problem.
However the boiler is not modulating temperature properly and when it gets to 60 or 70 degrees it cuts back down to 30 or 40 before warming up again. He changed the heat exchanger and the problem still occurred.
The boiler engineer has blamed it on a build up of scale and says it cannot be fixed. He told me to use some descaling liquid for 4-5 weeks then drain it out!
Is this easy to do? Is it likely that a 4 year old boiler will have that much scale that it does not work properly?
Regards,
Jack
