VOKERA BOILER
11 Jun 2009
I HAVE A MYNUTE HE VOKERA GAS BOILER AND AM LOOKING TO CONNECT UP THE INTERNAL FROST STAT IN THE BOILER, CAN ANYONE HELP? :?
What are you wanting to connect it to?
I'm fairly sure your boiler has built in frost protection which will protect the boiler from freezing.
It will not protect the whole system.
What are you trying to achieve?
and please turn off your CAPS LOCK
I have a 3 core flex coming from seperate clock in house to feed vokera boiler, but i need a seperate permanent feed to the boiler but i do not know what terminals they are to be terminated to on the boiler.
Has anyone got any ideas on how to fix this problem? Please!!!!!!!!!!!!!!!!! :?
Look at the manual. It tell all.
Link to Manual
I have a 3 core flex coming from separate clock in house to feed Vokera boiler, but i need a separate permanent feed to the boiler but I do not know what terminals they are to be terminated to on the boiler.
It is bad practice to have the boiler and controls fed from different electrical sources. There is then a danger that the engineer will only turn off the supply at the boiler and receive a nasty shock from the terminals fed from the clock.
You either connect the permanent supply to the boiler, which then feeds all other components - pump, motorized valves, programmer etc; or you connect the permanent supply to a central point, e.g a wiring centre, which then feeds all the components and the boiler.
Does the 3-core cable come from the switched side of the clock?
What system do you have - Y plan or S plan?
Do you have room and cylinder thermostats?
