I have just installed a new central heating system in a refurbishment project that i'm doing and I fitted an Ecotec 831Plus combi boiler. I have installed column radiators which has meant that my system volume is approx 150litres - (I drained down the system and got 130 out so added 20 litres for what would be left in the pipes). The boiler instructions says an additional expansion vessel needs to be fitted on the return for all systems with a capacity over 100litres as the expansion vessel in the boiler is 10 litres. - it recomends 24 litres for a 150 litre system.
Can anyone advise / recomend which expansion vessel I should fit and if I need a PRV, pressure gauge, and filling loop on it or would the PRV and pressure gauge in the boiler do the same job with the PV filling from the CH system? I assume the vessel just needs to be Tee'd into the 22mm return pipe under the boiler.
Any advise / recomedaitons would be greatly appreciated as I've never fitted a PV before
