Hi all, thinking about getting a new shower, mira divisa 9.8.
The electrical side of it looks to be ok, just change fuse from 40A to 45A (hopefully
) (will be done by someone qualified).
But I am worried the plumbing isn't good enough.
The current shower is fed from the water tank by 15mm copper pipe, which is about 4 feet distance from shower inlet (height). So I guess this makes it around 0.2 bar?
Will anything need to be done/upgraded? if the pressure does need raising, are there any other ways to raise the pressure with highering water tank etc?
Shower Requirements:
Plumbing
Minimum maintained inlet pressure for 9.0kW and 9.8kW, 70 kPa (0.7 bar)
for satisfactory operation
Maximum static inlet pressure 1000 kPa (10 bar)
Minimum static pressure 20 kPa (0.2 bar) to keep the inlet valva closed.
