Apologies if this is the wrong area, please redirect me to where I should post this if needs be. I have a number of questions around mains pressure systems.
We have moved in to a house which runs a worcester bosh junior combi boiler with no gravity fed system. The hotwater pressure is quite poor i.e. when two hot water taps are run the pressure drops from the boiler basically I think that the pressure from the boiler when two hotwater taps are running is poor even though our mains pressure is good (probably wrong size boiler for the job).
I have been looking at the possibilities of a Vented / Unvented Mains Pressure system for the hotwater instead, as we have no gravity system (so no pumps for power showers can be installed) and would like to have someone running a bath and someone washing up with no hotwater pressure drop.
1. Which is better? Vented or unvented mains Pressure systems or increase size of combi?
2. Where can vented /unvented systems be installed? Attic, Loft Space, Ground flooor level etc etc?
3. Can a combi boiler heat the Vented, Unvented mains pressure system?
Any ideas greatly appreciated.
Thanks again
Thanks again
