How to hold a bath tap still
15 Nov 2005
South
Cook Islands
...while I unscrew the headworks.
I have some Stilsons but they don't grip well once I have protected the chrome with a rag
sadly access to underneath is very awkward as the bath has been boxed in and blocked with a pipe duct, all painted over.
2 bits of ally, in the same way you use them to hold something in a vice.
plenty of tape on the spout but something that wont leave the glue on.
you mean in the stilson jaws?
:lol: I can see why you are puzzled, I use huge waterpump pliers for that. But yes, just to stop the steel gripping directly on the chrome/brass, stick some ally between the 2 surfaces.
boa strap wrench
that's a good idea. I should think you could use it on an immersion heater boss as well to reduce risk of crumpling.
The idea of using a rubber strap wrench either on stubborn tap headwork or a stuck immersion heater boss is preposterous.
To remove tap headwork, if your hands aren't strong enough, use an adjustable wrench on the spout to apply an equal and opposite force.
To remove, or tighten, an immersion heater, use the correctly-sized immersion heater wrench, and, if necessary, a hammer.
Then:
Classic. :lol:
Most of us `professionals` would use blowlamp to warm the threads. :wink: :lol:
The correctly-sized wrench is usually enough, so a hammer is rarely necessary, but when it is it's for tapping the wrench, not tw*tting at anything.
Meanwhile, you haven't offered any solution to the original question.
