Advice please from you plastering pro`s.
I cant find the info I want after several searches even though my questions seem fairly basic.
I`m building a simple stud partition wall with a doorway across my internal garage and lining the other three walls with plasterboard before having them and the existing ceiling skimmed by a plasterer to give a finish that will be ok for painting or papering.
What are pros and cons of taper edge v square edge board?
The walls are standard block cavity and one of the walls will be battened to stand off from cables on the wall. The other two will be dot & dab.
Any tips, dos & donts on these or anything gratefully received?
Mike
Mike
