A
ahdsh
What do you NOT understand?
I am providing a genuine service without breaking the law or without performing any tasks I am not qualified to do.
My charges are stated and I am fully public liability insured.
I have a 100% customer satisfaction record and not one client has asked for a refund under my full money back guarantee offer.
I do not have the qualifications you keep harping on about because they are NOT necessary either legally or professionally.
Do you have a HGV licence to drive your car? No... why? Can you work that one out?
If I was doing work requiring Part P or even Part P defined scope I would do the course. However I don't need to do that to add a socket unless it was outside or in a kitchen or bathroom. Guess how many of my clients have specified an alarm control panel outside or in a bathroom? NONE . . not one , zero zilch!!! If they want one in a kitchen then I use an existing socket , If they want one understairs or where an existing control panel has been then I run a socket from the existing spur.
So that makes PART P totally irrelevant to me so you can keep banging on all you like about it as it makes not ONE bit of difference to my work.
Jeez you like to get anally retentive don't you?
Putting to one side the non sequiturs that keep getting thrown in and skipping over the views held on the various systems, i read it as working on electrics per se. What the householder does to their property is their business. Being paid for services rendered puts a different twist on it.
Part P is but one aspect. Working on electrics without evidence of competency is at least foolhardy, doing so whilst being paid for said work could be argued to be contrary to the EAW regs. This covers work on domestics too.
Whilst the competency is issue is not defined in black and white terms i would argue it is a bit of a leap of faith to say it is not relevant.
The insurance company will certainly have a view if payout demanded.
Any connections I make to an existing spur are done with the correct flex (2.5 T & E) The fuse is changed if not already for a 3amp and when the socket has been added the socket is tested with a socket tester for earth impedance and the live and neutral for polarity.I am a qualified and certified PAT tester so can use the equipment required although in my case I have an upgraded tester that also gives a good - check - or urgent status of the earth loop impedance .In terms of other competency I have wired extra sockets to machinery and lighting in both domestic and previous work applications therefore having competence by experience. If the job requires any notifiable work under part P then I pass the work on or ask the householder to get an electrician in beforehand.
The draw to the socket is minimal being only Plug top adaptor type, input 230VAC 50Hz, output 9VDC, 500ma, tested to EN 60 950
Any bare earth wires are given a green/yellow sleeve from my toolbox.
I am totally confident that a three pin socket I wire up meets all the criteria required and would be happy to let any of my children or anybody elses children use the socket.
