wiring a house out and the customer is installing the above, he had no info on the electrical supply apart from it needs a "thick cable" "something that carries 50-60 amp".
I imagine the starting load will be large and that a type c breaker may be in order.
I am supplying the GSHP in SWA in a channel cut into the kitchen floor, the cable run is approx 8 metres. Im going to install a 16mm cable to be safe.
Has anyone any experience or advice relating to GSHP's?
