Both knobs came off 2 days ago. (Vaillant eco Plus 296)
Bad-knob day.
So now I'm stuck, the people who installed them say that I should be able to just 'click' it back in place but this is absolutely not the case and I have no idea what mechanism kept it in place so I can not 'reason' how to do this.
I looked at Vaillant's webiste but ordering a knob directly from them is probably going to be a complete pain as they try to direct you to the installing company first.
So are any of you capable of posting a picture of what the knob looks like when it is not broken ? I assume that my knobs are broken but I do not really see where it broke off from... Very strange.
I have a red plastic 'thingy' that fits inside the knob but it's only purpose seems to be to make noise when the knob is turned and other from that there's just the knob which has a 'stem' about an inch (2.5cm) long.. not long enough to click inside anything ! Was that stem longer originally ? Is that what broke off because there is no obvious sign of 'damage' at the end of it.
Hello,my problem is same-the heating knob fallen off
Getting colder every day an I dont know,what to do.Have You solve that knobs problem?
Ok. I can help you now
First off, I send an email to Vaillant telling him that I had this issue after I found out that the part you need is 1117319 (which are actually 3 knobs in a plastic bag, 2 big ones and one small one, the ones that are on the front panel).
They send me the part for free since it was still in Warranty.
The repair itself isn't hard really but obviously you can always have somebody do it for you.
What needs to be done : first take the front cover off, there is only ONE screw that you need to loosen for this : it is underneath the CV heater, right at the front. Once that is loose you can take the whole front metal sheet off.
Now you can see the innards , you will see that where the knobs go in is really a plastic box. And this plastic box can be released from teh frame easily, no screws or anything. Then you can open the plastic box open, if you wiggle with it you will probably already hear that there is something loose inside : it's the stems of the broken off knob(s) !
Look at the box, I believe there are 4 plastic lips that you need to loosen (just tilt them over the knobs that hold them in place). Once inside you will see the socalled motherboard, or PCB. And you will see that are two round places that oppose the place where the knobs would be inserted.
You may have to release the PCB (also held with plastic thingies) to remove the broken plastic stems but once they are gone you can easily insert the new knobs from the front. You will need a little power to click them in place though. The new knobs will have a longer stem than the original ones. Note that you can already get your heater to work without the knobs : all you need to do is take something that fits inside the round shapes on the PCB and turn them in the right direction (you can also use the broken off stem for this : just place it in the round shape and turn it counterclockwise to turn up or clockwise to turn down the 'volume'.
best regards, if you need more help just let me know.
Benny
