I have a single gas boiler that runs my hot water and central heating.
Today the central heating stopped responding.
About 2 years ago I replaced the changeover valve, water pump and fitted a new RW29 control unit (box only as it just replaced the failed unit)
Everything has been working fine until this morning when the heating just wont run. The RW29 control unit says the central heating should be on, if I advance the hot water that comes on fine.
I've reset the RW29 box which made no difference. The wall thermostat (T40) is pretty old. With the power off I've tested continuity between 1 and 3 when the gauge is turned and it goes on and off fine. With the power on there is 240v (well, 250 actually!) so I am at a loss on what to check next.
There is power to the thermostat, it seems to swith ok, the hot water is working and the control unit says it has switched on the central heating but nothing happens ..... I've tried with the hot water on and off.
Any sugestions (other than call an electrician) greafully received
