Hi! First post here, although I've been reading a lot of the helpful posts for some time, so I'm hopeful someone can help.
Every time our central heating system turns the Hot Water on, there's a loud "thump" from the pipework which I assume is an airlock. I've bled all the radiators (even though they're all hot and the noise only occurs when the hot water is on), but no air comes out.
I've had the auto air vent off from the feed into the hot water tank to confirm it was working and that water was available from the feed and expansion tank. All seemed ok there to.
Tried flushing the system from the drain cock to see if I could force any air back up to the expansion tank, but nothing seemed to happen.
The noise has been around for a while, but the effect of the airlock is more apparent now as No 1 daughter is back from Uni and the demands on the hot water for showers has suddenly increased! I assume the airlock is preventing the hot water from the boiler circulating properly to the tank and therefore there isn't as much hot water available.
Getting frustrated! Any help would really be appreciated.
Mac
Mac
