ecm module
16 Oct 2006
Lancashire
Can anyone please tell me where the ecm module is on a 96, fiat punto is?
or is it just another name for the ECU? THANKS.
ecm is abbreviation for engine control module, same thing as engine ecu. under bonnet on passengers side off the top of my head. can check at work tomorrow if needed.
cheers davie, do a check for me please, as mine is on the drivers side,ECU, are we def on about the same thing? keep getting info with different results
can give you more info if needed, like, i can pull a plug of a certain electric valve on top of, and beind the engine, and nothing changes, but this thing may not be important until excelleration ? (sp)
Spent a good few hours looking for advice for a cure, ended up on a fiat site in the F.A.Q. s, the ecm is the same as the ecu (thanks davie).
Had a mate up, did his reading an confirmed ecu, i see them on sale, the full trip, my mate has not heard of this, says don't buy second hand. but these have (as i believe) everything with them.
AM i on the wrong road.?
Daughter passed yesterday, and dosen't have a car yet :oops: :oops: :oops:
The fiat ecu is on the inlet manifold.
Iaw59f?? is the part number
BBA-reman also do them.
They do not need programming to the immobiliser as they do that on start up.
So make sure you put the right key in lol and you cannot reprogramme them so second hand is a no no
confusion? i was told there was an ecM at the inlet? ecu on the inner wing, which i know
The fiat ecu is on the inlet manifold. ???
Libby
Which engine is in it?
Autodata info......
If it's the 1.1 1.2 or 1.4 petrol engine, the E.C.U. is on the o/s inner wing. The 1.6 is in the centre console.
If you use the link I gave you and ring them, they will help diagnose the problem and give you a price for repair or exchange. I have used them a few times.
:wink:
the ecu on the manifold is on the 2000 onwards (facelifted) puntos.
another recomendation for the ecu doc by the way. great guy.
I had a problem with an ecu on a 51 plate 1.2 punto sits on top of inlet manifold
Engine misfired no spark from one coil pack.
Sent ecu for repair to Ecu- testing .com (find on ebay}
EXCELLENT SERVICE fixed for £100.
Recommened to replace coils with ecu repair
good luck
Paul
