I will apologies in advance as I have no picture but I'm going to describe my earthing set up.
The main L-N wires terminate before the main fuse in what seems to be some sort of metal block (Almost like a up turned triangle) the earth cable has been fastened below this around the incoming cable.
So I have an earth cable from the consumer unit to an earth block which I believe earth though the cable. Also from the earth block their is two more earth cables that seem to earth the out side of this triangle item one on each side.
Is this TN-S what does it mean to the choice of consumer unit? Sorry been reading another thread.
Now with image
Also the fuse carrier is metal and make 60amp max is this normal? Also a lot of green stuff has stainded the tile below should i worry
Now with image
