TN-C-S and TN-S in adjoining flats
10 Feb 2006
London
The ground floor receives a TN-C-S feed from which a TN-S feed is taken for the upstairs flat, along with a 6mm earth cable from the TN-C-S earth block. Both flats share the same water supply. The upper TN-S cable has a simple earth clamp instead of being properly soldered to the sheath. My feeling is to run a 16mm earth upstairs from the TN-C-S earth block. Am I correct?
14 Sep 2004
its upto the DNO to provide a reliable earth to their service head, unless its a TT system
