fault with hotpoint w541 aqarius
20 Oct 2009
Surrey
i have the above washing machine which is displaying the following fault - all lights flashing on the display. i have to turn the power off & on again to stop this happening & to get the machine working again. can anyone help?
yes i do, at the back in the corner remove rear white cover .
Firstly, thanks for your help so far. You do indeed rock!
Hello again, I left the machine as was for a while (ignoring flashing lights, as was still working). On the weekend just gone, I put a wash on & realised after a few hours that it was just running & running. It got to the stage where 'rinse & spin' 'wash' & 'final spin' lights where all on but cycle just would not end. I assumed the pcb had finally gone & ordered & fitted a replacement board. On doing this, the never ending cycle remained. Then F05 fault was indicated. So I removed pressure switch, blowing through tube & switch. All seemed fine. Just put back on again now, so will see what happens.
Any ideas what's going on with this? Is the pressure switch fault & never ending cycle related?
Please help!!
fo5 is a blocked filter or waste pipe full of gunge.that will cause it to wash all the time.check the filter and pipe .
Have just done that before coming back to the computer. Was absolutely full of crap! Seems to be running alot better now.
I'll let you how I get on.
Thanks again!
