I have a single storey extension - bedroom over a living area. It has a conventional pitched roof and the bedroom is in the roof space.
I've realised very large amounts of cold air are entering the space between the downstairs ceiling and upstairs floor. The biggest problem resulting from this is a freezing floor upstairs but I am obviously concerned about heat loss. The extent of the airflow can be quickly assessed by removing a downlighter - the resulting force of cold air coming down is very, very strong.
It seems as if the draughts/cold air are entering via the soffits, which are of the continuously vented (continuous rows of holes) UPVC type.
On a normal two storey house this ingress of air would obviously go into the loft, but in the case of my building it seems strange that the air goes between floor and ceiling.
So my question is, to what extent can I close the soffits or what other options do I have to reduce the gale going through the ceiling/floor void? I don't have a loft to keep aired so I am thinking that it would be acceptable to drastically reduce the airflow into the space I have described. It certainly seems as if the existing YPVC soffits allow an almost unobstructed flow of cold air into the house!
