Hi.
Plumber recently came round to flush our system as rads weren't working after not being used over the summer. He also replaced the three port valve (I wasn't there at the time!). Now, the heating will only come on if the hot water is also on, otherwise the boiler trips if you just demand CH only.
The single three-port valve appears to be working, in that it correctly switches to top/middle/bottom depending on what's demanded, and if I turn on the HW, then the CH, both circuits heat up fine. However, turn on the CH only, the valve moves correctly, but the boiler almost instantly trips and needs to be reset.
I'm convinced the plumber has messed up the wiring in the junction box, but I'm finding it hard to track down would could be wrong.
Can anyone come up with a mis-wiring that would cause this scenario so I can narrow it down a bit?!
It's a gravity fed system with a Potterton Suprima 30L with in-built timer and Drayton/Invensys ZA3/679 three-port valve.
Many thanks,
Chris
Not of much help, but I've attached a couple of photos. The first shows the airing cupboard connections - black cable is 3-port valve, middle white cable pump and bottom cable HW stat. The second pic shows the connections to the rest of the house (boiler,roomstat etc). Nothing's labelled which is why I'm having such a problem working it out!
Many thanks,
Chris
