Hi All,
Wonder if you can help.
Had a Danfoss 3 port Mid position valve replaced last year on my Y-Plan CH and HW system, the Plumber replaced it with a piece of rubbish, Altech 3 Port motorised valve.
The reason we had it replaced was the old valve body had got stuck in the mid position and trying to make it move caused it to leak.
Anyway, a plumber came and and replaced it with the Altech.
Problem is, we cannot now just turn on the CH as we could before with the old Valve, the HW has to be on too otherwise the Boiler and Pump do not fire. I did question the plumber on this when he was leaving, but he said this was how it was supposed to be, as the CH circuit doesn't power the Pump and Boiler on its own. I trusted what he said, as he was the professional.
He has since gone AWOL, and cannot find him!
I have examined the wiring diagrams, and have determined it is wired correctly. And from what I understand the Orange cable coming from the 3-port valve should fire the Pump / boiler once the Valve has moved into the CH only position. The valve is moving and can see it and hear it once in place.
The only way is to leave the HW on constantly, until the HW stat is satisfied, then the CH works on its own as such. But would prefer just to have the HW timed so it is just heating for a couple hours of the day.
Is it just a faulty valve? Or will this model just not do it?
[/img]
[/img]
