Mixer Shower - No hot water
17 May 2009
Cardiff
I have recently updated my mixer shower. It ran off 2 x 22mm pipes with a conventional shower hose and head. The 22mm pipes now run into a 15mm mixer tap, with piping fed behind the shower wall up to a monsoon style shower head but for some reason I have no hot water pressure. It's gravity fed. It worked the first few times and the cold water pressure is fine. I even had a pump installed which worked the first few times, but again, now all I get is cold water and when I switch to warm/hot the pump shuts down and I get no hot water at all.
My handyman bloke came and dismantled the mixer tap and the hot water flowed fine. He put the tap back on and the shower ran fine for 20 minutes. The second time I used it after he left, I had no hot water again. This has happened twice and no-one I know seems to understand what's going on.
Any ideas??
ask your handyman mate to see if there is a gauze anywhere on the hot side of the tap/shower. sometimes bits of solder and crap can get caught behind it and the flow can be reduced or stopped, especially on a gravity fed system. if there is, remove it and run hot for a good ten mins and clean gauze. hope this helps.
What height is the hot water cylinder in relation to the shower head? Try holding the shower head as low as possible and then turning on the shower - sometimes it can be too high for the pump and thus the flow to small for the pump to detect a demand
Is the cold water to the bathroom supplied from the mains or the tank?
Thanks for all the replies.
I'm not sure if the cold water is mains or tank, I will try and find out. The shower head is fixed to the wall so I am unable to adjust the height. The head is above the level of the tank though.
We thought it was simply crap stuck in the pipes, but even after dismantling the tap (everything looked okay, water ran well and no crap came out of the pipes) I encountered the same problem.
I thought the pump would help but it simply shuts down when I try to get hot water out of the shower.
The position of the hot cylinder has no effect on the flow to the shower. That is determined by the position of the cold water storage cistern
Are there any potential air traps in the pipework from the hot cylinder, say, from mounting the pump above the hot cylinder, or teeing the pump supply from the top outlet of the cylinder instead of using a surrey or essex flange?
Air trap seems the most likely I think.
Excuse my ignorance but what's the best way to get rid of the air?
My bad, i meant 'storage cistern' not hot water cylinder.
To remove an air lock connect open up the hot and you need to force main cold up the pipe somehow and for a while and then remove the pipe and allow the water to run out. This i have never done in practice by the way! :?
have a look in the FAQS and plumbing fixes and tips, a good detailed description of how to do it is in there
