- Joined
- 8 Oct 2005
- Messages
- 211
- Reaction score
- 2
- Country
I've recently installed an additional single rad via a motorized valve, but have found it's not staying warm. It appears that when the heating first comes on it heats up well, but then as soon as the rest of the house is up to temperature and the boiler is just cycling the water this particular rad doesn't get enough through flow to stay warm in the cold room. I've tried turning the lockshield valves down on all other rads, but with no effect.
I was thinking of installing another motorized valve on the flow from the boiler, and then re-route my flow pipe that feeds the new rad to the flow straight out of the boiler, but before the new motorized valve. In affect when the valve for the rest of the house shuts, the boiler will still circulate hot straight to the new rad, and not anywhere else.
The question is, is it OK to leave the return plumbed where it is, far away from the boiler where the new flow will be taken from? Or do I need to route that back to the boiler position too?
Thanks in advance.
Thanks in advance.
