6 inches of frozen ice on welsh slates
  • Thread starter Thread starter cabot
  • Start date Start date
C
cabot
i have the above problem on my rear elevation on a single storey bungalow.it is weighing down on the gutters and i am keen to get the ice off.what remedy can i do and would it be safe to pour boiling water on it to melt it
I'd say put some fan heaters in the loft pretty damn quick. :o
Be careful of the risk of ice damming. When there is literally an ice dam at the eaves so any melt water can't escape. It can build up to leak under the slates.
As long as you have an escape somewhere along the eaves, you should be OK.
unfortunately i cant get access to the loft .would pouring hot water over the affected areas cause damage to slates.sorry if it sound daft but extreme temperatures cause for extreme measures
You'll be amazed at how much hot water you'll need :idea: plus that can freeze where it falls providing additional hazards.
Might be better off with hairdryer/hotair gun or similar
Would spraying neat car windscreen washer fluid or de-icer have any effect?
