vaillant timeswitch 110 problem
20 Jan 2010
London
I have a vaillant TurboMax combi boiler, with time Switch 110, i set the time but however the radiators will not turn off when the time finishes.
It keeps staying on!
Any help, ADVICE!! ????
Obvious question. Did you set the mode switch to timed mode i.e. pointing to the clock symbol and did you ensure that the tappets were out for off and in for on?
The indicator light should go out when the timer is in an off mode.
Yep the obvious are checked.. all ok. the light stays on even when it is time for it to turn off
Hi amz003,
I'm experiencing a similar problem with my Vaillant Time Switch 110, to the one you described.
Did you fit a new timer? Did this solve your problem?
I look forward to your reply.
Thanks.
