Hello can anyone help me please?
I have just installed an Accent gen 4 with seperate lcd key pad.
Front door on zone 1 which is timed,hall on zone two kitchen on zone 3 living room on zone 4 and back door on zone five,Now the problem.....
I have programmed zone 1 to be timed,zone 2 to inhibit and also zone 4 to inhibit (as both pir's have got to be walked in front of to get to the alarm panel) .The alarm sets ok and lets you vacate the property whilst it is counting down the 40 seconds that I set it at but when you enter the property it starts its enter counting sequence (again set at 40 seconds)But once the living room pir or the passage pir detects you, the alarm then goes off even though they have been selected to inhibit. As this failed I then set zone two and zone 4 to a timed zone same as front door (as both pir's have got to be walked in front of to get to the alarm panel) but this also failed once either the hall (zone 2) or the living room (zone 4 ) detected me
Only 5 zones are being used and these are the only ones programmed to be used.I still have the strobe in test so the bell only goes off for 5 seconds max whilst I am setting up the alarm but I don't think the strobe settings have any impact on the programming of the entry/exit routes(or does it
) I guess it is prob something simple that I have done wrong but if so,then I can not see my mistake at the moment.
Any help or directions that that some one can give would be very help full.
