The T40/T6360 has the following connections inside it:
2 - Blue
3 - Green/Yellow (although i'm not convinced this is earth)
4 - Red
2 - Blue
4 - Red
Sure a wire was not on the terminal "one"
Should be
1 common
2 neutral
3 demand
4 satisfied
Under the paint, is that really a green/yellow wire, or a plain yellow wire?
The other colours, Red and Blue, suggest a 3 core & earth cable.
In that case, the yellow could be a live, switched live or a neutral.
it is almost certainly NOT an earth connection.
The earth wire from the cable may be terminated out of sight on the screw terminal in the back box behind the 'stat, athough most would prefer to see it connected to the earth terminal on the 'stat, with a flylead to the backbox.
If you do have a 3C&E, that looks like it is:-
Red - Live
Blue - Neutral
Yellow - Demand
If it really is Twin & Earth cable, it looks like someone has done something very naughty with the earth wire.
