I went to remove the heat exchanger and 3 way blending valve on my boiler this morning as the hot water is not as it should be.
I think either the 3 way valve is at fault or the heat exchanger is fouled.
I followed all of the instructions in the manual, i.e. closing the isolation valve from the heat store and also turn the small brass nippled below the DHW pump to isolate the system.
Also isolated the cold water inlet as well.
Proceeded to undo the connections and a little water came out but nothing major and was easily mopped up with a towel.
Then the big problem. Attempted to remove the large nut on top of the pump with a set of dogs and proceeded to unscrew it by hand.
Gush, gush gush. The water kust kept coming and I ended up screwing it back on.
Basically the water got under the floor and has stained the living room ceiling.
Does anyone know how to change this part as the instructions said to drain the pump via the screw on the front which I did. As the boiler is floor mounted I cannot get anything under the pump to catch the water
Any help appreciated
Lee
Lee
