Doing a bit of tidying up in my new flat I have noticed that the new consumer unit has been installed in a strange manner. Flat was rewired completely a couple of years ago apparently (mixture of old and new colours says otherwise...).
The original steel conduit (entire flat is wired in conduit) has been left as-is and the plastic casing of the CU has been hacked to accommodate. This leaves the conduit un-earthed, and although it is not used as the earth, this doesn't seem right to me.
Should I do anything about this? Only solutions I can think of are to use pipe bonding clamps or piranha nuts on the threads, however I think it is imperial conduit (built in the 60's)
Oh and the 2.5mm water heater feed on a 32A breaker is on my to-do list!
Colin C
Colin C
