There is a high pitched squealing noise when running any of the hot taps in the house or when using the gas shower run off combi system. The loudest is when using shower. When the downstairs tap is run the squealing noise still comes from the bathroom. A few times when running kittchen tap there has been a very strong vibration and loud juddering so much so that you can feel kitchen units shaking so I have to rurn it off as it feels like it will explode. This vibration and juddering sound has also happened a few times when running the bath, its quite scary actually.
This started a few weeks ago I don't know if its related to a few things I had fixed then. I had the combination boiler repressurised, a new washer fitted on the kitchen mixer tap and a new radiator valve and thermostat fitted to one radiator. The boiler and heating have been fine since but not sure if this is just coincidence that the noise has occured now but thought I should mention it just in case.
I have turned off the main stop tap and turned it back on again but the problem still remains.
