Vokera Linea 24 Isolation Valve
20 Mar 2010
Yorkshire
I replaced the DHW exchanger on my Linea 24 to cure the stop start hot water problem. It didn't work. Now the boiler gurgles and only stays up for a few seconds before reporting code 07 then code 02. I tried draining it and re-pressurising but no change. During all this I heard a loud bang and it turns out one of my radiators has burst. Even though the isolation valves are horizontal. When I try to re-pressureise the boiler it is putting water into the radiators. Anyone any clues or should I go straight to a plumber
fixed the same problem3 weeks ago, flow and return valve had been shut to do some work on boiler,re opened valves and boiler overheated with no flow
flow iso valve ball was closed although handle was turning :wink: :wink:
a number of issues here. :?
repressurising the boiler means repressurising the rads, its the same thing.
if the iso valves are "horizontal" it means they are shut.
if the dhw h/e didnt cure the hot water i would be looking at the dhw temp knob, the thermistor or the diverter.
